Restoring a 1992 Sylvan Eliminator 17'
Sasquatch5
Hey guys. Im new and i got some questions I hope someone can answer. Im restoring a sylvan eliminator. I've gotten the floor down and marine vinyl on. Carpet is ready to go on all sides but im at a stand still with the wiring. I wanted to move the battery more towards the bow. I extended the wires i needed to do so and noticed the the fuel guage, nav lights, volt meter are not working. I even blew a fuse on the electric trolling motor lines used on the bow. Does anyone know of where i can dig up a wiring diagram for my make and model? I noticed at the top of the page there was a post about generic boat wiring diagrams. I could try it but im hesistant on the fact im unsure if this nightmare project boat is of the generic kind. Any imput would be greatly appreciated. thx
Silvertip
Honorary Supreme Mariner
Re: Restoring a 1992 Sylvan Eliminator 17'
Did you try contacting Sylvan???? After all, they built the boat. The gauges on your boat are wired the same the gazillion other boats on the planet so they are indeed "generic". Follow the diagram in the stickies. Your trolling motor is on a totally separate circuit operated by a totally separate battery. Gauges need +12 volts and ground to operate. If either is missing they wont. A test light or a multi-meter (volt/ohm/milliamp meter) is required if you intend to do any serious troubleshooting. The fuel gauge, tachometer need a sense signal from the fuel tank sender and the engine sense line for those instruments to work. The voltmeter in this boat is telling you all you need to know. It only needs +12 volts and ground (no sense line) so obviously the gauges are not getting +12 volts or ground. That does not come from the battery directly -- +12 volts for the gauges comes via the engine harness and the "A" terminal of the ignitiion switch. If you are not the original owner of this vessel then only the prior owners know for sure what you have.
