Resto of 1967 Crestliner/ MFG DelRio
mstrvanmvr
I purchased this boat late summer last year and spent most time on mechanicals while trying to enjoy some fishing and tubing :) This winter I pulled the 1/2" rotted floor and replaced with 3/4" Marine grade Ply. I used the old floor as a template, because boat was stored in pole barn many miles away. I used Rustoleum Marine Spar Varnish 4 coats top and sides with 3 bottom coats =to thin for my liking ! I reinforced/renewed fiberglass between stringers and throughout bottom.Installed new foam and covered it up with new floor. I tabbed/peanut buttered floor to sides... not original and then fiberglassed floor with 6 oz. mat with another overlay of 4" tabbing. Finished with a resin coat with non slip additive sprinkled on. New Wise Back To Back Lounge seats from Walmart (that's right) free to store shipping and $20. cheaper than any other place I'd found ! I got the motor tuned with new Michigan Wheel 13 x 19.....still need tilt and trim tab adjustments on the 1974 Johnson 115, but first run pulled a respectable 42 mph:happy:Yesterday I wet sanded 2000 grit, swirl polish compound and waxed sides.Weather willing, I will try install of Airguide 665 Tach and Amp Gauges which were not wired last year and finish bottom and top side of boat ! I hope you all enjoy some of the picts. as much as I enjoyed working with her (Ms. MP) Ms. Money Pit/ also initials of my name :happy: Figured most picts are to large :facepalm:. Have to compress or something. This is a start. I will post picts of resto progress once I figure this out .
jbcurt00
Re: Resto of 1967 Crestliner/ MFG DelRio
Try using a free photobucket.com acct, that way the pix are IN your post & not attachments that need to be 'opened':
^^^Not me :watermelon:
mstrvanmvr
My photos were taken via camera phone and went to Dropbox account.The photos were to large , so I opened up Photobucket, but I'm learning as I go. I went under the advanced and added atatchments. I'll re- read the how to !
mstrvanmvr
mstrvanmvr
2013-05-15123014_zpsfdf0b6be.jpgI think that did it . I inserted attachment not image:facepalm:
mstrvanmvr
th_2013-04-30112456_zpsae0f2f72.jpgth_2013-05-01094441_zps5c0e5e0b.jpgth_2013-05-01094511_zps10088b8c.jpgth_2013-04-30112512_zpsfc8f5da2.jpgth_2013-04-30173637_zps7b704131.jpgI'll try the picts. as attachments not insert images!:joyous:
