resin companys and types
twintrades
I was looking at us composites 635 THIN EPOXY SYSTEM for my plywood boat. the 3:1 raio would this be a good place and type to use ??
Is there any other cheaper places out there ??
Re: resin companys and types
US Composites has better prices than anyone else that I've found.
The 635 Epoxy works well, I've had good luck with it. In choosing which hardener to use you need to take into consideration what the temperature will be when you do the work. When it was 95 degrees here I had to use the slow hardener to get a reasonable working time. Now that it's cooling off I'm using medium and fast hardener.
