Re: resin advise
D Grass, Do not forget to use cloth with whatever resin you use. Cover all seams with multiple layers of cloth to assist in water tightness when the boat flexes. I personally would use poly resin. It saturates into wood well (if you mix less hardener than usual), and on raw, dry wood sticks very well, much better than you will ever need. Using cloth on the non-seamed portion of the boat is desireable, but not essential. <br /><br />Also, if you can find some urethane foam, you can use it to fabricate nonstructual components of the boat. It is very lightweight and strong when reinforced by resin and cloth.
