Reproping my Bass Boat
gunlocators
OK I have a 98 Triton TR17 Bass Boat. It has a Evinrude 115hp motor and a 15 pitch prop I think 14 1/4" x 15 any way i know its a 15 pitch. With me I can hit 52mph at 5000-5100 RPMs or 46 with me wife and a one of my kids at 5000-5100 rpms. This is at full throttle and trimmed out to the max. I can never get it to 5600-5700 which the local marine dealer said it should be running at. With that said what do i need to do to get the RPMs up lower pitch prop higher pitch ? How will this effect top end speed?
gunlocators
Re: Reproping my Bass Boat
BTW not that ot matters i have a SST stainless prop on it now
gunlocators
This actually has a 17 pitch 13 7/8" prop I was wrong on the size
hwsiii
Gun, if your motor is a 1998 Evinrude with a Max WOT RPM of 5,500 RPM and a gear ratio of 2:1 you are not getting 52 MPH at 5,100 RPM as that is impossible because you would have a prop slip of -27%. In my opinion you either have the wrong speed or your tachometer is giving you the wrong RPM.
Prop Slip
If you will fill this form out I will help you.
Iboats Boat and Motor Info
1. Year, make and model of boat
2. Length, width and base weight of boat, look for boat decal on back of boat
2a.What is the maximum recommended HP for your boat
3. Number of people and gallons of gas normally on boat
4. What do you use the boat for
5. Is it a Deep Vee and if so how many degrees of deadrise
6. Year, make. manufacturer and model of motor
7. HP and gear ratio of motor IMPORTANT
If you don?t know the ratio, you need to pull the plugs out and put a piece of tape across the prop and the lower unit and then cut it between the prop and the housing then do the same thing on the flywheel and turn the motor until the tape lines up with each other on the prop, it is easier if two people do this, so one can watch the prop while the other counts the revolutions of the motor
8. Manufacturer?s recommended Wide Open Throttle (WOT) range
9. Anti-ventilation Plate height above keel of boat if it is an outboard in inches, use a board under the keel and stiking out to the anti ventilation plate for a referene
10. Is it a bass boat or does it have a pad bottom
11. Does it have a hydrafoil, dolefin or trim tabs
12. Make, model, diameter, pitch, number of blades and whether SS or aluminum prop
13. WOT RPM and speed from your current prop and how much gas and how many people were in the boat for the test data and is the speed by GPS. Make sure you trim the prop up until it starts ventilating and then just trim in until it quits ventilating. If you do not have a tach you can buy a Tiny Tach for $ 50
RPM ___________ Speed ___________ No. of people ____________ Gal. Gas ________
14. Are you at sea level or a higher elevation, give us the elevation in feet
15. Has your motor been tuned up lately and have you checked that the carburetor butterfly is opening all the way, checked compression, and looked at the plugs and checked spark, all of the foregoing could be the reason your prop is not attaining full RPM
16. How long has this prop been on the boat and why, at this time, do you think it is the wrong prop
17. Does the prop show any damage that you can see
18. What problems are you trying to cure or what are you looking for the boat to do that it is not doing the way you think it should or to your expectations
19. If you are trying to attain a better cruising speed and fuel savings or trying to attain a faster speed I will want you to take your boat and run it with 1 or 2 people and give me the RPM and speed readings starting at 3,000 RPM in 500 RPM increments all the way to WOT.
REMEMBER, The numbers I give you will be NO better than the information you give me
The only thing I ask of you is to come back and give me a report of WOT RPM and speed for my database.
H
