repower, need help with pitch
jackd1023
1995 Chaparral 1930, 2500lbs aprox
5.0 (250 hp)alpha one gen 2 1.62 gears
now have aluminum black max prop 19 pitch 3 blade
comes out of hole like a champion
Hitting rev limiter at WOT 4800 RPM (Spedo inop, phone gps would not give me speed)
I like the hole shot but while trimmed out bounces rev limiter,
Would it be smart to get a 21 pitch?
Tail_Gunner
Re: repower, need help with pitch
Sounds right..find a donor prop....No problem huh....:D One never know'd until you experiment...5.0 19' boat 22p is not out of sight... But a 21 sounds safe
jestor68
A Solas Rubex L3 SS 15-1/4 X 19 will get you off the rev limiter(est -200 rpm), still provide strong hole shot, and run 2-3 mph faster throughout the rpm band. :)
A 21 would drop about 400 rpm and slow the hole shot.
Tail_Gunner
Jestor that's a 19' boat fresh 5.0 1.6 gearing...you could be right but that combo runs a 21 7 days a week been there done that many times even a 4.3 will turn a 21 most of the time. But i like the pick.
1.62@4800 19p 10%slip gets 48 now 260hp 19' that a tad slow
1.62@4800 21p 10%slip gets 53 260hp 19' is still slow
Most I/O engines are very weak above 4500 and if you can pop the rev limiter easily generally your two to 3 pitches off
jestor68
The Mercury prop selector comes up with 14-1/2 X 19 SS props suitable for his boat. I suggested the larger diameter Solas to further load his motor and get off the limiter. A SS 21 will definitely get way off the limiter.
Go with what ever you feel comfortable with.
