loco
Thread starter- Joined
- Apr 25, 2010
- 154
Hi all,
As a background, I replaced my volvo AQ205A with a Repower Marine vortex lump, but brought the ancillaries over.
Yesterday, the steering suddenly became heavy. We stopped the boat, and the V belt had come off, with the pully loose, with loose bolts, and the pully having been pulled over one of the bolts. The pulley & pump was very hot. There was resistance in the pump as I turned it by hand, but didn't feel like it was siezed or anything. I stuck some washers on it, and put it all back together.
When it first cranked, it made a fairly unpleasant noise, but steering was fine, and we limped back to the harbour. We checked the engine again, and everything seemed back to normal. There was no heat or noise to indicate a failed bearing.
So, my thoughts: If the pully bolts had just worked loose, that would have caused it to wobble, and could explain the damage to the bolts, and the friction of the belt could have caused the high temperature. That said, the bearing could have jammed, then broken loose, and it might just be minutes before the thing fails catastrophically.
They say if there's any doubt, then there is no doubt, so it might be wise to get the part swapped out anyway. It could be as old as 1989. Thing is, it's ?500! Link to the keypart unit below...
Are there alternatives I can use? It's a v-belt model, and nothing too special. Can I use any pump, so long as I can make the bracket and hose threads fit?
Or, does anyone know where I can get a reconditioned unit like this, preferably from the UK?
As always, massive thanks in advance. Typical for a part to fail mid-summer, in high season!!
