Replacing trailer bunks
carrotsnapper
I was wondering if there is a best kind of wood for my bunks. I've thought about treated lumber or that artificial stuff they use on a backyard deck or just regular pine. My bunks are 12 foot long 2 X 6's. Any ideas?
colbyt
Master Chief Petty Officer
Re: Replacing trailer bunks
Southern yellow pine well painted or sealed is reputed to be the best choice. Treated is not recommended because of the chemicals leaching (very bad for tin boats). The plastic stuff is not available in 2x stock.
Silverbullet555
I don't remember what I used but it was probably pine or fir from home depot, 2x6. I wouldn't use pressure treated. The reality is that every once in a while they will need to be replaced.
newcomlr
If you ever saw the artificial wood boards laying on an uneven surface for very long, you'd see why it's not suitable for bunks. Needs many more support points than bunk structures provide.
Highlander70
i have seen a few threads that have used pressure treated but on fiberglass boats.
So is it just tin boats that you shouldnt use pressure treated? just wondering why is all.
Thanks
colbyt
The chemicals used to treat the wood can corrode the metal. Even the fife of hot dipped galvanized nails and fasteners are affected. The old CCA style wasn't quite as harmful as the new stuff.
Jonnybbad
The old treated lumber used arsenic, which is poisonous, but not corrosive. The new method uses copper, which will corrode other dissimilar metals when in contact, including when wet carpet separates the metals.
carrotsnapper
I used Home Depot 12 ft 2X6's. They seemed to work fine. I got them installed yesterday at the Provo Marina on Utah Lake. I love these projects. Whenever I'm working on my boat, I'm good. Thanks for your help.
