Replacing the floor on a RIB
Magnet6x6
Guys I'm new to working with fiberglass and know little about it other than it makes you itch.<br /><br />I suspect the hull or deck on my Osprey Eagle 5.6m RIB is letting water in as it drains for hours after being used.<br /><br />I need to inspect under the deck to see where the water's coming, (nothing obvious is visible from the outside), in and to check for rot but don't know where to start.<br /><br />I'm particularly concerned about knowing where and how to cut as I don't want to cut through any stringers.<br /><br />I'm anticipating having to replace the deck and whilst doing so I want to install under deck fuel tanks.<br /><br />With all this in mind can you offer me any advice or possibly point me to a project that has been through this sort of thing.<br /><br />All help gratefully received
