Putzaroni1
- Oct 20, 2012
- 108
The button for the shorting switch on my '74 9.9 is broken and I have one on a donor motor I'd like to replace it with. It should be just a matter of swapping them across but I cannot remove them because the housing (clip) that clip into the wires going to the ignition are too big to fit through the hole where the switch mounts.
Is there a way to pull 2 the housings off ? I see on Shop2.evinrude.com that the housing is a separate part but I don't want to break them taking them out and putting them back together.
Any suggestions on the trick to get them out ?
