Replacing Manifold and Riser Elbow
juice69
OK, I've done the work on my 2005 mercruiser 3.0 for the last 4 years that I've owned the boat. It's now come time to replace the exhaust manifold and riser (I'm in salt water). I've seen a couple youtubes on replacing the manifold and riser, but those were for a v-8 and volvo. The theory is pretty much the same, but they always make it look too easy - like starting with everything close to removed. I've also read service manual 26 and this seems like a doable job. I'm always open for advice, and i guess my first question is where's a good place (besides iboats) to get a complete manifold/riser with all the gaskets for the mercruiser 3.0? I wouldn't mind buying siera, but i want to make sure i get the right one. Would be a big PITA sending this wrong order back!
Second, should I do anything with the carb as it needs to come off? For some reason, i have feeling the carb removal/reinstall is going to be the worst part of this job. Finally, any advice is welcome. If there's a good link for this process, I'd be happy to know about it.
dubs283
Re: Replacing Manifold and Riser Elbow
the carb removal/install is the easiest part, if your concerned about how it all goes back together take lots of pics
sierra is probably what you will get here on iboats, ive never ordered from here but would bet either sierra or osco, they are both reputable OEM replacement manifolds
otherwise, you can go OEM used but used is used, so caveat emptor with that route
get yourself some long studs or bolts with the same thread pitch as the manifold bolts and cut the heads off, you can use them as "cheaters" in removing and more importantly installing the new manifold
ENSIGN
Ditto about the long studs
cr2k
I have had good luck on ebay.
scottn83
ebasic power is were i have boat most of my engine parts and they have the manifolds in stock
juice69
Thanks everyone. Great idea about using long bolts to hold the new one in place. Would've spent a few hours using bad language otherwise.
Anyone use Marines Parts House? They have the manifold (with gaskets and bolts) for $298, the elbow for $147 and shipping for $70.
rick3452
Very good luck with Lighthouse Marine "partsman" Osco was very good USA quality, but ONLY use OEM Mercruiser Gaskets....
