I have a 1990 Johnson GT150 that I am replacing the lower unit on. The lower unit I am replacing it with came off of a 1996 Johnson 175. This shift linkage a little different so I pulled my old one out to put in the new unit. I adjusted the length to where the old one was according to turns. When I put it together it will not quiet go far enough in either direction to go in gear. I've adjusted the cable and can get forward or reverse, but not both.
Can someone tell me what the height of the shift rod is suppose to be on a 20" lower unit. I thought I would try that unless anyone has another idea?
