Replacing Impeller Sears p/n 26251
pugbro
I have ordered the above part and will attemt installation when it arrives..This engine ,217/585880, runs great even after being in storage for over 15 years, but I figured the impeller need to be replaced due to dry rot. what type of gear lube should I use in the gear housing after the installation...Are there any other vital parts that need changing, before taking to the waterways?
Thanks
Drowned Rat
Re: Replacing Impeller Sears p/n 26251
Add 90 weight marine gear oil to the lower unit. If it still runs okay, change the impeller and run it.
