HereDuckyDucky
Thread starter- Joined
- Jul 8, 2010
- 13
I just bought a '96 15hp (E15REDS), and I would like to replace the impeller, pump housing, etc., just to be safe and so that I know how to do it in case of emergency.
I've changed impellers before, but I rant into a problem with this motor. I can't find where to disconnect the shift rod so that the lower unit will slide off.
I'm assuming that once I remove the six bolts holding the unit to the midsection and disconnect the shift rod the LU will slide off and I'll have easy access to the impeller housing.
So two questions:
1. Am I right in my assumptions on what I need to do?
2. If so, where do I disconnect the shift rod?
Thanks in advance!
RW
So two questions:
Thanks in advance!
RW
