replacing gimbal bearing/ 140/3.0 mercruiser
hal27
i need help? im replacing the gimbal bearing in my 85 cheetah! i need to no how to get the bearig out without tearing anything up along the way? is there any specialty tools i need? or should i replace any other parts, o-rings,gaskets,or bellows while i have it tore down? i have takin the drive unit off and there was dirty water holding in the one bellow that the driveshaft runs through! i have cleaned and lubed everything now ready to change bearing.
Wotknot
Re: replacing gimbal bearing/ 140/3.0 mercruiser
Might read up on how to replace u-joints, too.:(
Bt Doctur
Might also consider changing the boot as well. no sense filling the new bearing up with new water too.
jedimaster
Buy the bellows kit not that much more considering the pita your gonna have putting it all back together.
First time I did mine it took me hours and hours. I think I could do it again in less than an hour though.
You will need a few tools,
Alignment tool, bellows expander(Although I made due without one).
a slide hammer to get the bearing out
and that should be enough
read the manual as posted above. Print it out and follow it word for word.
Rob454
Like it was said above.
a slide hammer
alignment tool
those two are a must
bearing driver ( but I use a soft brass bar to tap the bearing in)
the other stuff I woudl jsut replace because youre alerady there
the alignment tool is gonna run you abotu 90-100$
the slide hammer probably 40-50
Rob
whywhyzed
Banned
I couldn't get mine to budge with a slide hammer - seems the transom just kept absorbing the impacts I ended up making a real simple threaded rod puller.
wcsparky05
where's westminster? rob 454?
jedimaster
Your really gonna have to heave on it good to get it out, its possible that its rusted inplace. you might want to try soaking it down with some good penetrating fluid for a day or so first. Release All works good.
Fishstick1962
Sometimes when they are really stuck it helps to drive them in to break'em loose. Then pull 'em out. As KJDKJD said, I've had to use a piece of all-thread and a plate with the puller screwed on the end to get them out too. They can be a PITA. It is not coming out without the puller. And an alignment tool is a MUST after re-installing the new one.
Good luck!
