Replacing carpet on alluminum gunwales?
acarter92
Well, I just bought an 89 "Blue Fin" 17' sportsman fish n' ski alluminum. I'm getting ready to replace the carpet on the gunwales and front deck. It's about 6"-8" wide and goes all the way around, covers both consoles, and a small deck on the front. I'm looking at the cabelas "Deluxe" Marine carpet for the job. The problem I'm having is what glue I should get, the stuff that cabelas sells has horrible reviews. I'm going to be glueing the carpet directly to bare alluminum, what glue should I use? Any specific brands? This is quite a job, remove all the trim work, lights, hardware, windshield, and dash boards. So I don't want to have to do it twice, at least not any time soon.
Thanks in advance,
Austin
Fireman431
Re: Replacing carpet on alluminum gunwales?
Try this:
http://www.pontoonstuff.com/marine-boat-carpet-glue.aspx
Follow the instructions closely. Aluminum will need to be sanded to remove residue and oxidation and then wiped with a solvent prior to the application. Most are 2 part applications. Spray to the boat and the back of carpet & wait till tacky, then apply.
5150abf
I used outdoor carpet glue I got at Lowes and it worked pretty good, I didn't try it on aluminum, only wood but it seemed really tacky and should work.
The stuff Fireman put should be alot bettet though so I think I would go with that.
Georgesalmon
I have used weldwood contact cement for many years in my boats with no problems. Manufacturers I worked for also use contact cement.
jigngrub
Weldwood contact cement, the kind that comes in the can.
One coat on the aluminum and 2 coats on the carpet.
ezmobee
I never understood having carpet on the gunwales.
