Replacement Windows
BoatBuoy
I'm thinking of replacing the aluminum frame windows in my brick veneer home with new vinyl windows. Is there anybody that has attempted this and what was your experience?
OBJ
Re: Replacement Windows
I had replacement vinyl windows at one time. Didn't like them. Finally replaced every window in the house, frames and all, with windows from Peach Tree. They have excellet vinyl clad windows and you can get parts or replacement windows (in case a baseball goes through one) direct from there factory. They have a web site. <br /><br />Sizing may be the problem. My house is vinyl siding so I could go bigger or smaller and cover it up. Brick is a different ball game.
Fly Rod
:) Is there any wood trim around the aluminum frame, or does the fin of the aluminum frame go behind the brick veneer???<br /><br />If you have wood trim the job should be very easy, just take accurate measurements of the opening and the manufacture would deduct for the replacement window to fit the opening!!! ;) :cool:
BoatBuoy
There's no exposed wood trim. I'm sure the opening is wood-framed though.<br />Here's a shot of an outside corner:<br />
<br /><br />This is an inside corner:<br /><br />
Fly Rod
:) The outside picture looks like the fin trim goes behind the brick veneer, if it has a fin!!!<br /><br />You may have to do a little exploring from the inside!!! Remove the slipper casing,the finish board that goes aganist the interior aluminum, there should be a space between the window frame and wood,take a thin saws-all blade or pick etc: and push it towards the outside and you have to determine if there is a fin trim and if there is then you a job cut out for ya!!! Most aluminum windows do have a fin!!!<br /><br />One other thing is when interior window sash is in the open position look and see if any screws go into the wood framing!!! Could be 2-3 screws along the jamb and if that is the case you may be able to pull the window out after releasing the screws on each side!!!! ;) :cool:
stan_deezy
Well BB if my translation is correct and vinyl windows means uPVC (that's the British version) then I can give you my experience of them; great!<br /><br />First time we had them fitted to replace rotten timber framed windows and we paid megabucks to have it done :( but.........I spent two days watching exactly how it was done and learning the little tricks :D <br />Next time we did it ourselves to replace aluminium framed windows and it wasn't difficult at all and with a nice bead of silicone you can "hide" some mistakes :D <br /><br />Of course maybe my translation is wrong in which case ignore this post ;)
dtherrien
Yeah Boatbouy,...Harvey makes the top of the line vinyl replacement window.You have to have them sized correctlyfor each window.Also you will not need your storm windows with the new ones.
