I would personally keep looking for the proper length. Although the toons would support the weight, the distribution would be off.
Without knowing more about the boat itself, I will speak in general here, correct me if I am wrong for this model. The bulk of the weight is at the stern of the boat. Batteries, fuel tanks, and of course the giant hunk of metal that propels the boat. Moving full forward will cause the stern to drop significantly, maybe dangerously low.
Mounting fully to the stern would expose the deck to waves and such, not ideal.
The mounting of the outboard (assuming it is an outboard, if it is a i/o boat don't even attempt this), would have to be changed. The boat would be riding 7" higher. That would not work with your existing setup.
Of course you can try to split the difference and balance the boat at just the right point so the prop is sitting in the water correctly and the bow is lifted somewhat out of the waves, but loading and balancing the boat with passengers constantly would be a never ending struggle.
If he trailers the boat, have to take into account modifying the trailer as well if it is a bunk trailer. Where is the winch post located and will the boat load properly?
That is a lot of modification just because he found a good deal on local toons for something that he might be able to balance out.
