Replacement prop
TOMBLAZER
Need a prop for a johnson 120 v4 1995. Motor ser.#3649854. This motor is on a 24 foot pontoon barge.
M
Maxz695
Guest
Re: Replacement prop
what came off it is this the original setup?
steelespike
Pontoon performance and prop selection varies widely pitch could be from about 15"
to 11" on similar sized pontoons.
idealy you would run the present prop and get the max rpm and speed.
If we're going from scratch I would start with a 13" 4 blade.
The 13 could be undersized but thats better than too much prop.
Maybe try to find a dealer that will let you try props to find the right one.
Usually requires a deposit with the understanding you will buy a prop.
