Explorer2002
Thread starter- Joined
- Oct 2, 2009
- 1
I have a Mariner 222R Trolling motor (mid 1980's) and one of the blades broke off. I need to replace it and wanted to know if there is a prop that is similar to what I had. The prop that I had was a Quicksilver Machete model # 48-18024. it was a two-blade prop 10 1/2" long (blade to blade) the center hub measured three inches and the shaft length is 3 1/2 inches long. The prop pin is on the shaft and the prop must sit firmly on the pin to properly work.
I had purchased it a few years back from a boat dealer in North Carolina (forgot the name - otherwise I would re-order from them).
Any help/suggested would be much appreciated.
SS
Does anyone know what prop is compatible with this trolling motor?
SS
