replacement of spring on 4hp pull starter
tyerfish
I need to replace a broken starter spring on a 1987 4 hp deluxe Evinrude. It is a model E4RDHCUD and the starter mounts to the port side of the block. It is described as a swing arm gear dive starter. I have an OMC manual but it does not give any real detail on how to replace just the the spring. I need to do this with out buying any special OMC tools. So far, all I have done is remove the shoulder screw so I could look inside the starter assembly to see if the spring was broke and of course it was.
boobie
If you have the genuine OMC manual the procedure should be in there.
tyerfish
I do not have an OMC manual but I do have a Clymer Outboard shop manual for evinrude. I do not want to buy another manual for an old 4 hp.
tyerfish
thanks for your help in locating this manual. I seem to have only one problem with the site. When I try and print a page, all I get is a black piece of paper. No picture or print is produced. Other than that, I can read the manual just fine on the desktop page.
