Drivewayboater2
Thread starter- Joined
- Aug 21, 2019
- 396
Hoping to get some information regarding what else I need to take off ( and reuse) from the old 5.0 and transfer to the new( reman) long block. Here’s the list of what Ive currently done.
removed, inspected, cleaned, painted and rebuilt:
carb
intake manifold
distributor
risers
power steering pump
valve covers
spark arrestor
thermostat housing
fuel pump
went through wiring harness- cleaned and inspected all wires and connections
I will replace the water pump
I assume the starter works but haven’t removed or bench tested it. Still on old block.
I also assume that the entire bell housing that connects to the block to the outdrive will be reused. That still needs to come off old block as well. What other items ( if serviceable) can/should be transfered? Thanks in advance for any advice.
carb
intake manifold
distributor
risers
power steering pump
valve covers
spark arrestor
thermostat housing
fuel pump
