I have a 1990 Thompson Carrera 205 with a 4.3 l mer ruiser and alpha one outdrive 1.84 gears when I bought it everything was fine the boat ran at 40 miles an hour and steered great no plowing. After a couple times in the water the upper gears went out because the previous owner filled the oil from the top. so I bought a new outdrive geared the same put it all back together and now the boat only does 30 miles an hour. The bow plows through the water and is hard to steer. You need a raincoat to be in the boat at full throttle What could I have done wrong?
