flyinguitars
- Jul 1, 2014
- 14
You definitely extended the life of the old girl! I did something very similar to my old boat but I used furniture oak when I sistered the stringers. I noticed that you screwed the deck down....I did as well, and I also glued it. And you coated the deck with resin. I did this as well. Your deck is probably way better now than the factory if it were like mine. Mine deck was stapled in, and no glass or resin, top or bottom. Anyway, enjoy your boat!Also, I coated all of the wood surfaces with 2 coats of resin on the bottom and 3 coats on the top side. The first coat was cut with acetone to get it to penetrate. I used 2.5 gallons of resin. The sum of parts/materials was approx
Polyester resin is pretty much worthless (weak and brittle) without fiberglass cloth or matt to reinforce it, no matter how many coats you use. It'll crack, flake, and peel in a couple of years and anything applied to it like carpet or paint will lift and separate from the plywood the resin was applied to.... but y'all will find this out later.
