replaced gimbal bearing in merc alpha 1. cannot get alignment tool to engage with engine coupler at all. have tried to move bearing every way
bgabbe
replaced gimbal bearing in alpha outdrive. cannot get alignment tool to engage with engine coupler at all. tried to move gimbal bearing every way but no positive results.
any suggestions?
Bt Doctur
Was the old bearing destroyed or was the drive difficult to remove? If yes ,you have an engine alignment issue
Grub54891
How old is the boat? Sounds like something is amiss. A few pics would help I think, Some of the gimble area, transom, and engine areas.
any suggestions?
Ayuh,.... Welcome Aboard,....... Did you inspect the rear motor mounts, to be sure they haven't collapsed,..??
Did you get the hardware stack in the right order,..??
tank1949
any suggestions?
Try beating alignment shaft side to side. Pray your transom is not rotten.
ROY WILLIAMS
any suggestions?
well the engine bearing is new .. did the bearing of the alignment rod tool inside of it ..did the rusting of the drive shaft outdrive leaking the bellows worn out and leak it ...
chartersj
you probably figured it out by now but if you cant get the tool to go in take a 1" bar/tube and that will go into the coupler and give you a visual of which way you need to go
