Good day sirs. <br /><br /><br /><br /><br />In the old days when I worked on 50's & early 60's Evinrudes there was a small plate with two screws to remove on the mid / lower section in order to disengage the shift rod and drop the lower unit to replace the water pump. I am about to attempt to replace the water pump/impellor on the above mentioned motor but do no see a plate as I am familiar with. I do see a small hole that appears to be plugged with something. It is in about the same place as the old plate. Does this have to do with the shift rod? If not is the water pump and lower unit as simple as it was a long time ago? Hope this makes sense.<br /><br /><br />Your replies as always are so very appreciated .
