replace anchor light
edlaff1
I have to replace my anchor light on my key west 2020WA and cant easily get to the wires (they are way down below where the base used to be!). Is there an easy way to get at the wiring? Any suggestions. Thx.
Splat
Re: replace anchor light
Sure, gfrtab the wires and attach new anchor light! Not very helpful huh? neither was your question. See where i'm going with this. No where enough information here to even attempt to make a educated guess.
Are the wires still attached to the current base? Did they fall through the hole where the base used to be?
Can you use a coat hanger to reach down and get them?
Can you fish new wires down the hole and splice them in somewhere under the deck.
I mean really come one try to give us something to work with here.
Bill
edlaff1
I was hoping that a Key West owner knew a trick for getting access to the wiring source for the anchor light base. You're right Petty O, it really wasn't an informative post.
There really was no trick. It took a coat hangar, new wire, liquid elec. tape, and lots of patience. It's all rewired and working!
Thanks.
