Replace 2 stroke powerhead with a 4 stroke
harkawy
I searched and could not find the answer to my question. There are many lakes that will not permit a boat with a 2 stroke engine larger than 5 or 7 horsepower. I have a 1995 Force 70. It is a three cylinder two stroke engine. Can the power head be replaced with a three cylinder four stroke keeping the lower drive unit? I know, its like trying to stick a Chevy Corvette engine into a Ford Mustang but I think it might be less expensive.
eurolarva
Re: Replace 2 stroke powerhead with a 4 stroke
pretty sure it wont work. The only chance you have is if merc will work and I doubt it. You need the thing to mount up to the kingpin and seal up so exhaust dont get in. Also you will need the powerhead to be the correct diameter with the same amount of splines and the correct height. It can probably be done and look real ugly doing it. Then there is the issue of getting the control cables to work with it.
AlanR
Sell your 1995 Force 70 outboard, take the money and buy a 4 stroke. LOL
deejaycee_2000
nope there is no way that would work, the easy way is to sell your motor and buy a 4-stroke ......
