I have a 1 inch crack in the clear plastic portion of my canvas top's side curtain. Would you recommend some epoxy to seal the crack or some other form of treatment to keep the crack in check? thx sd
you should be able to stop the crack by drilling a small hole at end of crack and fill that with silicone. Not sure how you would get a sealer in the crack.........t/42
thx Wo-max, just ordered it on-line. Thx for the lead. Any advice as to whether I should put put it on the crack from the outside of the plastic or inside of the plastic (or both sides)? thx
