Repairing a water logged boat
chipndale
I have a 1970 Bayliner Tri-hull that was stored uncovered in western Washington several years before I bought it. I could never seem to get much speed out of the 65 Hp Mercury outboard that came with it. This spring I was in the process of re-building the seats and noticed that there was water oozing form the screw holes. I have since removed approx. a 4X6 ft section of the deck and found the flotation foam to be soaked. What is the best way to remedy this situation, other than scrapping the boat?
NoKlu
Re: Repairing a water logged boat
Sound's like you may have a big job ahead of you. If the foam is full of water the stringers are probably shot as well. Check them for rot. The transom will need to be checked as well. All of the foam and rotten wood has to be removed and replaced. Never had the pleasure myself but can be done with a lot of time and money. There are a lot of threads on this forum detailing the job ahead, read them first and then you have to decide if you want to go ahead with the project or scrap the boat.
Ayuh,.....
You can drop Another $2000. to $4000.,+ about 400hours labor into it,.....
Or,...
Scrap it......
I'd go with the latter,....'cause if you Fix it,... It'll only be worth 1/4 what you spent.....
