rivergoddess
- Aug 9, 2007
- 1
Plastic part on shift lever inside control box broke, finally found replacement part, but can't remove rotating shift/throttle plate to install replacement part underneath. We removed central screw (that appears to attach to shift lever outside the box), and other apparent screws, but rotating plate won't detach. How is this plate removed so the part that fits underneath can be installed?
