Looking for suggestions on width of outside transom board, material and bolts. I have ended up with two 14' Alumacraft fishing boats with early motors and am excited to get them in the water. The aluminum is good but both have transom problems. The 1950's FD has a punky outside transom I want to replace and the 1960's was always stored outside and is mostly gone. My plan is to remove the outside transom that is just punky and use it for a template to make two new ones. A helpful post from 2012 by Backwaters 2 used 1/2' for the outside and 3/4" oak plywood for the inside. I just need to replace the outside transoms on these two boats and note the manufacturer made these out of 1/4" stock. Thinking of using 1/4" marine plywood for these outside transoms with polyurethane. Any advice on material and width for this? Is 1/4" ok? Marine plywood? Also, wondering if something else needs to be done with the bolts to prevent leakage? Would appreciate any tips from someone who has done this before. Thanks!
