Repainting inside of boat - couple of questions
Scuda11
Hi all, I am getting ready to paint the inside of my 20' Proline CC. The link is just to some pics before I do it.
http://www.oceansedgewebdesign.com/boat2007/index.html
My plan is to use Interlux Pre-kote, and then Brightsides as my topcoat. I just used that combo on my rod holders and they came out great (pics are on the link).
After I remove all deck pieces/cleats, etc my plan is to use some Interlux 257 filler for my holes. Then sand with 120grit (it's pretty smooth already), then 220 grit, then prime with pre-kote, repeat sand then 2 coats of Brightside.
I am not doing the console, that was done last year.
Am I on the right track here? I guess I am just looking for confirmation.
Thanks in advance.
ondarvr
Re: Repainting inside of boat - couple of questions
I think the reason you haven't gotten any replies is because what you've already done looks pretty good and you did the console last year, which in the pic looks good too. If what you've already done has held up for a year and your happy with it, then I would just continue with that method.
Scuda11
Good point, didn't think of that. Should have mentioned that I didn't do the console.
Thanks though, appreciate it.
tthomas
What year is your boat?
Scuda11
1972 hull
Untitled Document
Thanks in advance.
Ayuh,.... The key to a quality paint job is the Prep,...
If All the surfaces are Smooth, 'n sanded with the fine grit paper, it oughta come out nearly Perfect....
ezmobee
Ya think he painted it by now Bill? :D
Scuda11
Yes, he did!
lakelover
edited--smilies not showing up! ??? (Sorry to not contribute to this old discussion!) :D:D OK, there they are.
