FORUM RULES UPDATED - The forum rules have been updated to continue to provide a friendly and safe environment for our member community. Please take a moment to review the updated rules and our terms of use and privacy policy. Click here for Forum Rules which has links to the 'terms of use' and 'privacy policy'.
In Other News . . .
You will notice a few enchancements to the forums to make your experience better. These include: Email Notifications, Thread Previews, Thread Starter Notation, and Emoji Options on the 'Like' icon. . .
Additionally, the merchant portions of the website have been updated and are now operational. . . . Check out iBoats for all your boating gear.
I was looking at a 225 on ebay and the stated he had removed the thermostats due to overheating. Since the thermostats open at a relative low temp..(140 I think) would this be a problem?
Yep,<br /><br />You don't want to run that motor without the stats... They are designed to regulate the water flow through the heads and ensure proper cooling capabilities in relation to the temp.
You can remove the stats, but you must install a washer with a 3/16 hole in it to regulate the water flow. It will also burn more gas with the stats out. good luck...
