removing Suzuki DT8C powerhead
tairua
HI, I could use some help removing the powerhead of my 1995 DT8C outboard.
So far removed the carb. oil tank and CDI and the lower unit, and 4 bolts + 2 nuts at the bottum of the upper unit. Tried to remove the powerhead by tapping it with a wooden hammer, but it doesn't come loose. Are there any other bolts to remove I have forgotten about.
James R
Re: removing Suzuki DT8C powerhead
Go to brownspoint.com for the drawings and parts listing. This will show if there are any bolts that you have missed. If all the bolts are out then a small pry bar under the head will shift it.
