ward cleaver
Thread starter- Joined
- Dec 15, 2007
- 174
I removed the screws on the exhaust housing of my 1961 Johnson 40hp motor. What a struggle. I started out all 12 screws with liberal doses of WD40. Seven came loose after a couple of hits on the impact driver. Three more required quite a few stern raps but did come out ok. The last two were trouble. After banging with the impact driver failed, I ended up having to cut a wide slot in the phillips head with my dremmel so that I could use a large flat blade screw driver turned sideways. Even then it was a major struggle.
I took a close look at the screws and I see that the threads of the reluctant ones are filled with what looks like corrosion to me. I soaked them in mineral spirits overnite but they still won't allow a nut to thread all the way up to the lock washer. Are these screws ruined? What is this stuff in the threads?
