hkeiner
- Oct 17, 2006
- 1,055
My motor seems to run fine with the Idle Stabilizer module still installed. However, I have read several recent posts about the wisdom of removing this module to avoid potential problems from a module failure, such as mentioned in this link: http://forums.iboats.com/showthread.php?t=417952
I am planning to remove the module on my motor to be on the safe side, but I want to be very clear on how to do it without messing up the timing. Removing the module itself is the easy part for me, but I am a bit unclear on the how to set the max timing with the module permanently removed. The shop manual provides timing specs (21 at cranking and 19 at WOT)), but I expect these apply with the stabilizer being used on the motor. Plus I am not sure I understand all that is said in the manual about the idel stabilizer and what applies to my particular motor. I do know how to set max timing at cranking speed.
Further, the above linked posts states that timing should be 23 degrees if the module is permanently removed, but does not mention if this is at cranking speed or WOT.
In short, these are my questions:
- What should the max timing show (with a timing light) at "cranking" speed and what should it shown at "WOT"?
- Do experienced (wise) mechanics actually check the timing at WOT out on the water or are they happy with the 'cranking speed" max timing adjustment.
I ask this latter question because I once tried to check the timing at WOT out on the water and it seemed like a pretty crazy thing to do. My boat goes pretty fast...
