Mandrake35
- Jan 23, 2009
- 89
Hi again!, I just got back with all the seals for my lower end, and while I was at the parts counter the guy recommended a points kit. I'm hoping once I get the flywheel off I won't need coils also. Question is..... is there a trick to removing the flywheel. I've removed the nut, but it won't budge. It's getting a good soak of WD40 right now. Can you use the threaded holes in it to force it off? Do I need a giant gear puller? please help It's a 1965 9.5 hp Evinrude sportwin model 9522c
