pine island fred
Thread starter- Joined
- Dec 20, 2002
- 1,144
Cut the drive shaft in half to drop the gear box. Started removing the water pump and am now looking at the plastic block with 3 stainless studs. What can I expect to find to remove the shaft from the gearbox? Seal and pressed on bearing? Do have a SELOCK manual but it covers so many different set up as to be confusing. Dont want to start prying on things and cause more damage than is already done. 92, 40 hp. mariner 4 cyl. thanks fred
