Re: Removing Corrosion
I recommend mechanically removing as much corrosion as possible (don't use a wire brush as that will cause more corrosion from dissimilar metals), treat with Alumiprep per mfgr instructions, treat with Alodine, and finish up with an appropriate primer. I always use an epoxy chromate, but there may be other suitable primers.
Mike
