HawaiianRawr
- Nov 6, 2010
- 10
Ok here is my situation my friend is "losing" his boat it's a 1978 Sea Ray and I bought the engine and complete outdrive from him, well this morning I completely removed everything around the engine and got everything stripped down to a long block and removed the bell housing bolts etc, the steering cable is disconnected as is the bracket that bolts to the outdrive from inside (steering bracket) , I also removed the electro mechanical tilt unit as a whole and removed the engine mount nuts.
Basically I paid $200 for a low hour 383 Chevy rebuilt 4 years ago and a VP 280 outdrive with 400 hours on it.
I'm hoping I could just remove the 6 outdrive nuts going thru the transom and remove the whole outdrive as a whole, is that possible? the only other outdrive I messed with before was a old 800 stringer omc and I just about shot that thing haha.
I would really appreciate a heads up as to how to remove the outdrive, I'm a pretty good mechanic but my outdrive experience is limited.
Also, since I removed my bell housing bolts and engine mount nuts shouldn't the engine just pull away and up from the outdrive???? Is my thinking correct there?
Any and all help is appreciated I'd love to have the outdrive pulled today if possible
Doc?
Doc?
