removed and replaced fuel pump, now wont start
will_tn
I blew a freeze plug this winter. Boat started fine after winter, but freeze plug forced me to remove fuel filter and motor mount to replace plug. Plug in, no leaks and it started fine on first test. After a minute it stalled and quit. Won't start again. It's like it ran out of fuel. Fuel pump comes on (a soft whirring sound as key is turned), so I dont think that's the issue.
Could there be something with the filter I screwed up. If this were my outboard, I feel like I could pump the bulb and solve my problem.
Bt Doctur
Re: removed and replaced fuel pump, now wont start
The fuel pump is not supposed to come on with the key on. There is a pressure switch involved. Did you reverse the fuel pump wires.
Is there fuel at the carb inlet
Don S
It will if he has an EFI engine. But he failed to mention engine type, make, model, year, marinizer or anything else.
He needs to read THIS if he wants any real answers.
Bt Doctur
your right Don, but my Magic Ball showed a carb. I know your is a lot clearer. I must have a older model than yours.Maybe the poster will include the necessary info to make a clear decision possable.
Don S
Look close, mine has a crack in it............. Bummer :rolleyes:
