Remove Tilt Trim Motor on 1978, 70 hp Evinrude
Charles King
Can the Tilt Trim Motor be removed from the Engine while on the Boat. Is a special flexible shaft needed to access the back, inside stud?
Thanks
retiredfornow
Re: Remove Tilt Trim Motor on 1978, 70 hp Evinrude
I believe it's easier to pull the whole unit to remove the motor. Nice engineering for that back bolt, huh?
Charles King
I agree 110%.
Maybe we need to design a special tool??
boobie
With the right 1/4" drive sockets and extensions I have taken them off before, but it's a bi**h.
retiredfornow
Seen a guy remove the port stern bracket to get to that screw. That was a pain!
Charles King
Thanks Admiral!
At 85 years, I have always found :
Boating is a Bxxxh, not a Beach"!
Will post my results.
Charles King
I've tried all but removing Motor! It looks like removing motor is only way on this BXXXH !
retiredfornow
I removed the bolts holding the trim & tilt unit, then removed the whole unit to get to the t&t motor. It takes a little wiggling to get it out, but it's do-able. Good luck.
