Remove Prop????
BULLWARKS
Do you remove your prop at the end of the season?
Silvertip
Honorary Supreme Mariner
Re: Remove Prop????
Why would you -- unless you were storing the boat outside and were afraid of theft.
walleyehed
Re: Remove Prop????
It's a good Idea to pull it at the end of the season to check for fishing line wrapped around the shaft, which can cut oil seals...it's also good to clean and grease the splines each fall, then re-install.
BULLWARKS
Re: Remove Prop????
Thanks walleyhed.<br /><br />Anyhttp://www.myfishingpictures.com/img/043850.jpg<br />Avatar Image problem leaving it to SPRING???
BULLWARKS
Re: Remove Prop????
WOW THAT LAST POST GOT MESSED UP.<br /><br />I wanted to say thanks walleyhed.<br /><br />Any problem leaving it till spring??
walleyehed
Re: Remove Prop????
No, I guess not...But I always change lower unit fluid in the fall before real cold weather hits, and for customers, that's when I check prop-shaft..<br />I change props so often on mine, I have a rag-bag and grease on board...
