The iboats forum moderators are excited to announce that at this time it appears the iboats forums posting pictures function is working once again. Though we cannot promise for how long, we're hoping for indefinitely.
This outboard has internal .4 gallon tank. Run time 40 min. max. How can I run a line with bulb from external tank to this motor? Any suggestions would be interesting. Thanks
i dont think you cam because the tank on that motor is gravity feed and does not have a fuel pump.if you can get the tank higher then the engine you will be ok. but i dont think thats gonna happen.you can always carry a gallon or 2 jug with you nad fill it as needed
You would need to install a fuel pump<br />and of course the appropreate fittings.<br /> Youll need to find a place on the crankcase<br /> to hook up the pulse port for the fuel pump.<br /> Wouldnt hurt to check with a dealer to see if there is a remote option.
