Bayou Dave
Thread starter- Joined
- Dec 13, 2012
- 1,780
I believe that is a commander sidemount. You remove the handle by loosening the setscrew on the underside of the handle. From your question I am guessing that you art having trouble with the trim. If so the problem is more likely to be the trim limit switch in the stern than the wires in the handle, pretty easy to check to determine where the problem is.
HERE is the manual for that control.
Don to the rescue again! You must be a walking repair manual for all boating questions. Thanks....
