Reinstalling Starter Johnson 130 1990
robert.tadefa
I reinstalled the starter after changing out the carbon brushes. I thought I knew what I was doing, but when I try to start, the started clicks, but does not raise high enough to reach the flywheel (if that is what it is called).
May be wiring?
JB
Re: Reinstalling Starter Johnson 130 1990
Hi Robert
Welcome to iboats. :)
Sounds like hidden corrosion in connections of the battery cables. Take off both ends of both cables, scrub them shiny and reconnect.
Let us know the result, and good luck. :)
robert.tadefa
It turns out when I was re-assembling the starter, I failed to insert the 4 springs in the cap, under the carbon brushes. Works perfectly now.
However, the tilt only went down and not up. I wanted to share this with others, although I read it in one of the other threads. The first thing to do is to test the relays. What I did was simply switch the 2. Instead of only going down and not up, it was reverse. Obviously I had one good relay and one bad one. Easy to replace.
