reinstalling outdrive
stevejeri
I am trying to reinstall the outdrive on a 1983 140hp after a bellows and gimble bearing replacement. It is an alpha 1 outdrive that goes on so far and then stops. It looks like the u-joints are hitting the housing. Any tricks to getting it back on?
Haut Medoc
Re: reinstalling outdrive
Did you check the alignment with an alignment tool?...:confused:​
Bt Doctur
did you recheck alignment after replacing the gimbal brg.
U joints really cant jam up in the housing , more than enough room.
Is the shifter in full fwd gear.and it the drive in full fwd gear.
bruceb58
Honorary Supreme Mariner
Did you use an alignment tool to check your alignment? When you do this, it also sets the angle of the gimbal bearing correctly. If you don't do this, you are going to have a tough time.
Fishermark
Looks like all three were typing the same thing at basically the same time.
Yep, What they said! ;)
Also, if the u-joints are getting loose and sloppy, they can make reinstalling the outdrive a bit more of a challenge. Might want to think about replacing them as well.
buggiedad_67
did the same thing as you, found out engine had droped just a touch and had to rasie it, once i did it slid in and works fine now, also make sure it is shifted all the way into foward
stevejeri
Thanks to everyone for your suggestions. I got it in, but now no reverse. I had it all the way forward for the remove an install, and forward and neutral are fine, but no reverse. With it tilted up, I can see the shifter lever turn when it is shifted into reverse, but the prop still spins freely. Any idea what went wrong? Do I need to pull it and try again? Reverse worked before removal.
buggiedad_67
Thanks to everyone for your suggestions. I got it in, but now no reverse. I had it all the way forward for the remove an install, and forward and neutral are fine, but no reverse. With it tilted up, I can see the shifter lever turn when it is shifted into reverse, but the prop still spins freely. Any idea what went wrong? Do I need to pull it and try again? Reverse worked before removal.[/QUOT
take your shift cable loose and make sure you can move it all the way in by hand easily, then all the way out it should move freely, if not change your shift cable, if it does adjust your cable by the book and it should work fine
Don S
The roller probably missed being between the 3 arms of the shift slide.
