Reinstalling lower unit
codyr
Having trouble reinstalling lower unit on 88 evinrude 30hp. Stops dead about 3/4 of an inch from mating up. Nothing was specified about if it should be in neutral or not so I pulled it off in neutral. Should I have left it in forward to be able to rotate the shaft with the prop to line up the splines?
F_R
Honorary Supreme Mariner
That would work, or you can simply rotate the flywheel Remove the spark plugs first!
oldboat1
might do this: Figure out which shift lever position moves the shift rod up (forward or reverse) -- just toggle the lever a little one way or the other while watching the rod. Assuming you need forward gear, gently move the lever forward while lifting the lower unit up into place. May find that the unit moves into place without issues. If you find you need to line up the splines, do that by nudging the flywheel a little by hand (clockwise), or pulling a little on the manual starter cord, then try fitting up the l.u. again as above. Plugs out, as F_R says, for safety and to make it easier to rotate flywheel.
It does not matter how you take these apart.----Forward works ---Nuetral works ---Reverse works.
oldboat1
yup. kind of foolproof (doesn't matter what gear it was in when disconnecting or connecting upper and lower rod). Find reinstalling l.u. sometimes an exercise in patience, though. Can feel some resistance when pushing up the lower unit (and shift rod). Think it's either the detent up at the top, or forcing a gear change down at the bottom, or both. Sometimes makes it feel as if the unit is hung up and won't move up into place. Getting the water tube fitting smoothly back in place also sometimes an issue, along with getting the splines to mesh. And sometimes it pops back up smooth as silk.
