reinstalling impeller on drive shaft
codyr
I'm in the process of rebuilding the water pump on my 1988 Evinrude 30hp. I have the water pump removed and the impeller off the drive shaft. The old impeller had a retaining key, and my new one has a plastic cam tab. I have the factory service manual but the pictures are hard to make out. It says the sharp edge of the cam tab needs to be the leading edge during rotation, but I'm having trouble understanding how its installed. The impeller has only one side the key can be slid into. The other side has a lip. For the sharp edge to be leading during counterclockwise rotation I'd have to flip the impeller over and install it on the shaft with the tab, then install the shaft and impeller into the water pump housing. My manual says to install the impeller in the cup first, then slide the shaft and tab through it. I just want to be clear on this as the manual says displacement during operation of cam tab can cause significant damage. If anyone can clear this up I'd really appreciate it.
Ignore the manual.---Have the shaft in the lower unit.---Put the key on the flat part of shaft with some grease.---Slide the impeller down onto the key.---Push pump housing down onto the impeller while rotating the shaft clockwise.
Faztbullet
If your impeller was key driven the cam type wont fit as no flat spot on driveshaft for cam key...
